Galdhøpiggen is the highest mountain in scandinavia and our project of the same name is just as impressive. The modern architecture of its stacked and staggered building elements blends tastefully into its environment while the lights of the polygonal stories illuminate the harbor view in a warm pale yellow.
The minimalistic room-high windows of the glass facade offer a look inside this modern complex which consists of two identically designed buildings: the taller one is of seven stories and the shorter, four. Each also has an elegant green rooftop terrace.
Our architecture visualization brings out the aesthetic contrast between the light and mirrored levels, which artfully reflect the sky and the deep color of the sea.
MORE INFORMATION ABOUT OUR WORKS YOU CAN FIND ON
https://render-vision.com/type/3d-architectural-visualization-service/
