This is a personal project I’ve been meaning to do for a long time. I wanted to primarily learn how to use RailClone, so a brick façade was a no-brainer.
I used ZBrush to create the bricks and distributed them in three different patterns using RailClon. Due to the limitations of RailClone Lite, I could only use 3 segments (or 3 unique bricks) per RailClone object, which was challenging at first, because I didn’t want to see repeating bricks on the building. The workaround was to use transform nodes in RailClone to rotate each segment several times in 90 degree increments. This way I could get 4 unique sides from each brick, and ultimately get 12 unique looking bricks instead of 3. Using procedural and triplanar texturing techniques helped out even further to get a more random, natural look.
I also personally took the backplate photo, which proved to be extremely helpful because I had all the information for the camera matching afterwards.
